8/27/2008 1:57 PM | |
Joined: 9/11/2006 Last visit: 3/17/2022 Posts: 168 Rating:
Hi are you using the same machine that used to have V5.1.If you unistalled sybase which is used by wincc V5you might get errors when doing bthe migrationeven though wincc V6 uses SQL.the following link might help: http://support.automation.siemens.com/WW/view/en/17066607 |
