6/3/2012 7:18 PM | |
Joined: 11/6/2009 Last visit: 12/7/2024 Posts: 13 Rating:
Hi guys I have sort of a similar problem when i try to install wincc on virtual machine. I get the error message MSI file initialization failed: ERROR_OPEN_FAILED I tried to folow dec's advice and copy all the files to the root folder of the vm (C:/TempInst) but i get the same error. I atached the install log Thanks Micky
AttachmentSIA_WINCC_PROFESSIONAL_V11.zip (736 Downloads) |
Last edited by: O_Moderator at: 6/6/2012 11:06 AMnew subject after splitting from /tf/WW/en/Posts/61805#top |
6/3/2012 7:21 PM | |
Here is the print screen of the error message i am getting |
6/6/2012 1:40 PM | |
Posts: 3037 Rating:
Hello, You use Windows 7 64-bit. Which WinCC V11 version do you use? As from version STEP 7 V11 SP2, STEP 7 V11 is enabled for a 64-bit operating system in the Windows 7 and Windows Server 2008 R2 operating systems. Welche SIMATIC Software lässt sich unter 64-bit Betriebssystemen installieren? Tweety |
6/8/2012 12:46 PM | |
Posts: 3037 Rating:
Hello, you should start a Support Request on the customer support. --->Support Request Tweety |
