5/2/2019 8:02 AM | |
Posts: 2 Rating:
Hello every one, I have a problem when sending SMS via CP1242-7 GPRS. I run my program but TC_Con, TC_Send indicator 07000 status and no sms is sent, who can solve this problem, thanks
AttachmentPictures.zip (241 Downloads) |
Last edited by: Jen_Moderator at: 05/02/2019 13:03:55Inserted headline as text in the post. Optimized headline. |
5/2/2019 9:18 AM | |
hi, how could anyone know what you are doing? Please describe particulary what you want to do! What CPU do you use? Which engineering SW do you use? TC_CON and TC_SEND? are you sure? Have a look here: How do you configure open IE communication via the integrated PN/IE interface of the CPU or via an Industrial Ethernet CP? To get the Error of the system-blocks see this FAQ: How do you evaluate the status of system blocks in STEP 7 (TIA Portal)? The more we know, the more we can help! |
FCK WAR! |
5/3/2019 12:02 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello Perhaps this Basic FAQ helps: https://support.industry.siemens.com/cs/de/en/view/58638283 Bye Murof |
2/21/2021 10:30 PM | |
Joined: 5/22/2013 Last visit: 11/13/2024 Posts: 49 Rating:
Didn't help too much :( Do you know what is that ??? |
2/22/2021 7:54 AM | |
Joined: 4/25/2017 Last visit: 3/20/2025 Posts: 436 Rating:
Hi, You need to install the missing HSPs
Best Regards, |
