8/17/2015 11:15 AM | |
Joined: 8/27/2010 Last visit: 6/3/2022 Posts: 417 Rating:
Good morning!) Can you post a drawing of how conection been made? |
8/17/2015 1:16 PM | |
hi Jens, you should connect your transducer as a 4-wire-transducer. 4-wire-transducer are with a seperate power-supply, which you have with your pins "+" or "L" and "-" or "M". Where your analogue Output-Pin should connected depends on the measuring-device. Maybe you have to connect the M to the device too. SIMATIC S7-300 CPU 31xC and CPU 31x: Technical specificationssee the manual on page 279 hope this helps, regards, |
FCK WAR! |
8/18/2015 10:20 AM | |
hi Jens, thats the way it should work. regards, |
FCK WAR! |
8/18/2015 11:31 AM | |
hi Jens, how are your settings? Is it parametrized as 4-wire-transducer? reagards, |
FCK WAR! |
