2/13/2019 8:33 PM | |
Joined: 10/14/2012 Last visit: 9/16/2022 Posts: 8 Rating: (0) |
Hello, i have one problem with actual speed value ,,r63'' ,this is wrong display in (Transmit Direction field) ,i make speed control and torque control with torque limitation . Could you help me with some advice on this problem ,below I loaded the movie with this problem. The problem persists when the motor is turn off,I tried to change the the motor but the same problem. Thank you! https://www.youtube.com/watch?v=kqDEmocyM8E ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/14/2019 12:21:12 PMNew subject after splitting |
