4/4/2012 7:43 AM | |
Posts: 2348 Rating:
You can treat it as 1-dimension ARRAY 1..1500 to use with indirect addressing. Please change View to Data View in STL for details. |
4/4/2012 9:59 AM | |
Joined: 10/7/2005 Last visit: 6/5/2023 Posts: 2966 Rating:
don't give up so fast dear Carlos73and allow me (well Siemens) to present you with a pre-programmed example on how to work with a two dimensional array in STL: How can you access an element indirectly in STL in a two-dimensional array (e.g. a value in line 2 and column 5)? Havingsaid that, handling of these type of arrays is more convenient in SCL, but I hope this helps anyhow. |
Cheers |
