7/25/2014 6:10 AM | |
Posts: 204 Rating:
Hi Xuanphu, Ethenet communication is pretty simple in s7-1200 . just follow this manual>>Manual
7/25/2014 5:51 PM | |
Posts: 146 Rating:
Thank you for all replying ! I'm using TIA portal V12 ,,,First CPU (PLC1) for send data : 1214C - FW 2.0 and receive data CPU (PLC2) 1215C - FW 3.0, I upload my file ...Pleae change extension file from ZIP ---> RAR and unrar this ! With this file I want to start the pump from (FB1) DB3 run pump from Q0.3... I want to you this block from PLC1 send data to PLC 2 control pump ... Best regard ! AttachmentCM 2014 Project1 ver 3.zip (349 Downloads) |
7/26/2014 1:47 PM | |
Posts: 146 Rating:
Please help me to solve this problem.... I try many times to do it ..but unsuccess ! Thank you very much ! |
8/4/2014 11:18 AM | |
Posts: 146 Rating:
Hi ..sir ! Thank you for replying ! With my file I sent to you when you downloaded ..please change the extension from CM 2014 Project1 ver 3.zip to CM 2014 Project1 ver 3.rar .... ..Then I attach my sreen shot for you : ..Please tell me how can I write the code andf put them where ? Best regard ! |
8/4/2014 11:46 AM | |
Posts: 146 Rating:
Yes... I want to copy I0.3 to MB10..then at PLC2 copy to MB12 and get to Output at PLC 2... Did you open my file OK ? Thank you very much ! |
