6/17/2007 5:05 PM | |
Joined: 1/7/2006 Last visit: 2/16/2023 Posts: 2705 Rating:
Hi, I have found a Multi-FAQ with all possibilitys to communicate with the panels. When I might beleave the excelsheet that is also coming with the FAQ then you need a6ES7901- 3DB30-0XA0, that is te one you have. So that must work... As you mentioned you need a version 5 cable |
