8/9/2012 11:15 AM | |
Joined: 4/22/2010 Last visit: 12/9/2021 Posts: 5697 Rating:
Hello, First there is no upgrade to v3.0 because older CPU's cant be upgraded to V3.0, Read more here Second : The right way to Reset to factory settings. Regards, Marcjan |
Problem solved? |
8/9/2012 11:58 AM | |
Hello, I think your PLC needs firmware file, since V3.0 is not available for download,you can try Firmware update V2.2 Please follow the directions given in the link. If no result i suggest --> Support Request Regards, Marcjan |
8/9/2012 12:29 PM | |
Posts: 4 Rating:
Thank you, I'll try with that |
8/9/2012 3:04 PM | |
Posts: 4 Rating:
Ok, tnx, I will try that also |
