7/28/2010 7:32 AM | |
Joined: 7/26/2010 Last visit: 2/24/2025 Posts: 6 Rating:
New Problem - Since we have bought the TP177B now, we want to use it because of the increased functionality. Problem we have not been able to download our project. We are given an error to check the cables, interfaces, etc. The TP177A has no issue with downloading. Any ideas? Splitted from Profibus communication with TP177a. |
7/28/2010 9:44 AM | |
Joined: 4/24/2006 Last visit: 4/23/2025 Posts: 8965 Rating:
Dear Ash Man, Can you explain which cable you want to use? Best regards, Wizard |
7/28/2010 3:15 PM | |
Ok, Please have a look at this link: how can you transfer a WinCC flexible project serially to a panel?
Do you mean in Hardware configuration of Step 7, in properties of CPU? If you can change from MPI to Profibus, it means you will no longer have a MPI port. You need to program using Profibus. Best regards, Wizard |
