2/15/2022 11:29 PM | |
Joined: 12/21/2021 Last visit: 10/3/2022 Posts: 7 Rating:
Hello Everybody, I have problem with installing the "Wincc Unified Runtime PC V16 Security" update. The installer write that the: "Simatic WinCC Unified PC V16.0 could not be found", althought I have already intalled the WinCC Unified PC and I also can use it in the TIA Portal V16. This is the problem with the "Update 1 of WinCC Unified PC Runtime" also. Any solutions? Thank in advance Regards, Balazs ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/16/2022 10:45:50New subject after splitting |
2/16/2022 3:49 PM | |
Hello, I have checked it, and as You see, the Unified is installed. Regards, Balázs |
