4/27/2015 12:44 PM | |
Posts: 4 Rating:
Every time you restart, the Op is in first page and the application don't start Thanks for help |
1/23/2018 8:53 AM | |
Joined: 4/24/2006 Last visit: 5/25/2022 Posts: 8435 Rating:
Hello, Perhaps you can try to 'reset to factory settings', see the following link: USB Recovery (Reset to factory) Mode for 2nd Generation Basic Panels Best regards, Wizard |
1/24/2018 9:40 AM | |
Joined: 5/19/2014 Last visit: 10/12/2021 Posts: 5 Rating:
I can't download Basic2nd_Recovery_System.zip (24,6 MB) from https://support.industry.siemens.com/cs/ww/en/view/109744950 message: "You cannot download this file, since your registration inquiry is still being processed. Please note: due to the manual review, the registration may take several days. You will get a confirmation e-mail as soon as your download registration is finalized. You can download the software packages with export restrictions only when you have received the positive confirmation." waiting for autorization ?? I already tried Prosafe tool, but connection could not be establish as well as dowloading sotfware from TIA portal , although panel reply on ping command and reacts on flash led command from TIA Portal I noticed also that sound doest work on panel (this annoying beep), and panel looks to work slow BR |
