7/7/2022 9:18 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Roby Check in Windows if MSPaint is set to default program for the common Graphics. if you create a new project, is it the same behaviour? If nothing works you can also use the Graphic Export Tool to export and edit the Graphics. https://support.industry.siemens.com/cs/de/en/view/109562021 Bye Murof |
