12/23/2013 8:29 AM | |
Posts: 3 Rating:
Hi All I have follow the instruction to set my CP443-1 and CPU417-5H to set the NTP function (NTP Server is my PC) https://support.automation.siemens.com/WW/adsearch/resultset.aspx?region=WW&lang=en&netmode=internet&ui=NDAwMDAxNwAA&term=ntp+cp&ID=22144502&ehbid=22144502 But the CPU cannot sync with my CP443 (even the CP443 sync the NTP server successfully), However, the CPU can sync with the NTP server successfully when using the PROFINET port. Dose anyone can help to slove this problem? |
