10/23/2012 5:32 PM | |
Posts: 1547 Rating:
Hello, it seems to be, that your runtime system crashed. There is no setting how can create this. I suggest cleaning the system form Siemens Software and install again. Repair or over install will not work. Follow this FAQ and uninstall all SIEMENS software in Step 1. Use all steps as described, then your system is clean and you can start again. How do you uninstall STEP 7 completely, including all the software packages? |
