6/19/2009 1:43 PM | |
Joined: 3/21/2006 Last visit: 12/2/2024 Posts: 10229 Rating: (1181) |
Hi, Let's assume that will use 7MH4950 type module.( By the way I have already known from Siwarexi that this FB45 is not useful for other type SiwarexU module)Thank you! . So look at manual SIWAREX U - Universal weighing module for SIMATIC S7 300 and ET 200M(MLFB 7MH4950-XXXX) (from 59th page). Perhaps there you could find answers of your question. Regards Hristo Mihalev |
6/2/2010 4:58 PM | |
Posts: 4 Rating: (0) |
Can you clarify the link to the manual? It does not work when clicking on it. |
6/2/2010 5:00 PM | |
Does FB45 work ok with the 7H4950 modules? |
6/2/2010 5:08 PM | |
Joined: 9/27/2006 Last visit: 12/10/2024 Posts: 12302 Rating: (2692) |
Hello vossman: Here is a new link to the manual proposed by Umencho: http://support.automation.siemens.com/WW/view/en/28392477 By the way, you can locate all Siemens automation manuals easily, through the Product Support link at the top of the page (use the search box once you enter, and filter through the Manuals link). Hope this helps, Daniel Chartier |
6/3/2010 2:34 PM | |
Joined: 1/4/2007 Last visit: 12/10/2024 Posts: 1158 Rating: (175)
Hello Vossman, The FB45 works only with the 7H4950 modules. Best regards Siwarexi |
