11/22/2017 2:52 PM | |
Posts: 1 Rating:
Dear all, I have problem with touchpanel TP177 A . I will sent you a video of it so can you tell me is it just problem with screen , or i should by a new touch panel? This machine was not working about year and half ( the machine is for pulp moulding) , and now we turn it on and all was fine . But later the right side of touch panel stopped working. On the video you can see everything. If the problem isn't in screen , what is your suggestion , where to buy the touch panel? Thank you for your help. ------------------------------------------------------------------------------------------ AttachmentIMG_3922(2) (online-video-cutter.com).avi (40 Downloads) |
Last edited by: Jen_Moderator at: 11/23/2017 9:18:31 AMNew subject after splitting |
11/28/2017 1:49 PM | |
Posts: 648 Rating:
Hey Marta123, you should contact the technical support. Your touch Screen could be damaged. https://support.industry.siemens.com/My/ww/en/requests#createRequest With best regards rh1990 |
