2/4/2013 5:14 PM | |
Posts: 3037 Rating:
Hello, You should do an OSUpdate with Reset to factory settings. How do you do an operating system update (OS update) on operator panels? Tweety |
2/25/2013 3:23 PM | |
Posts: 2 Rating:
Hello, Tweety A problem consists of that does not turn out to whip off the system to the plant tinctures, because initial OS does not work. For updating of OS I use ProSav, connecting by means of parallel cable. The process of updating of OS starts and in the middle of updating torn off with a report(on a photo). Where my error? Dmitry Attachmentfoto.pdf (224 Downloads) |
2/25/2013 5:11 PM | |
Joined: 3/21/2006 Last visit: 2/6/2025 Posts: 10239 Rating:
You mast use RS 232 Zero modem cable (http://support.automation.siemens.com/WW/view/en/21401061). Try it with Support Request best regards, Hristo Mihalev |
2/27/2013 6:18 PM | |
Posts: 3037 Rating:
Hello, |
