10/30/2023 4:42 PM | |
Posts: 1 Rating: (0) |
I configured WinCC Unified but when I access to https://localhost, I had a problem. I'm using TIA Portal V17. Please help me! Thanks very much |
10/30/2023 6:21 PM | |
Joined: 8/6/2018 Last visit: 1/13/2025 Posts: 338 Rating: (45) |
Hello Did you encounter any errors when you installed WinCC Unified PC? Are you using the latest version? Thanks you |
10/31/2023 11:45 AM | |
Joined: 8/3/2009 Last visit: 1/16/2025 Posts: 14583 Rating: (1815) |
Hello nhuan2209 You should create your certificates for Unified and also run the Unified configuration. Check also this FAQ: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
