6/8/2009 11:21 PM | |
Joined: 6/13/2006 Last visit: 2/11/2023 Posts: 341 Rating:
Dear Ema, Having a dot in a tag name, behaves like a structure tag, hence you first simply need to creat a structure tag in a such a formate that can creat a tag which would be same a existing one in dot format. By doing this the existing will delet automatically. This did work in past see below: https://www.automation.siemens.com/tf/WW/en/Posts/23895 regards, rit03 |
2 thankful Users |
6/15/2011 11:30 AM | |
Posts: 73 Rating:
Hello Edma, I think the solution given by Darius would be ideal without risking any corruption to your project. You could make use of the "CC_VariableExportImport" tool if required to export and re-import your tags back into WinCC. Attaching the tool here, for your perusal. Regards, Krrish !! AttachmentCC_VariablenImportExport.zip (77 Downloads) |
2 thankful Users |
