8/17/2009 9:20 PM | |
Posts: 3 Rating:
Hi everybody, I'm having a problem with my diagnostic buffer. The information appears with unreadable characters, mostly ####. See attached. The diagnostic buffer used be fine before. My CPU is 417-4-H-A and I'm using STEP7 V5.3 SP2 + HF2. When I read this same diagnostic buffer from another computer, it works fine. So I think is some problem with STEP7 configuration. Any help is welcome. Regards, Darlam AttachmentDiagnose20090722.zip (36 Downloads) |
8/18/2009 7:54 AM | |
Joined: 11/15/2006 Last visit: 5/7/2021 Posts: 1319 Rating:
Check DCOM settings on your system as given in following FAQ http://support.automation.siemens.com/WW/view/en/16503255 Then verify whether you have SIWAREX software installed on your system and tell us the version you have. |
Have Fun! |
8/18/2009 7:56 PM | |
Posts: 3 Rating:
Hello, I updated my installation of STEP 7 to V5.3 SP3, but that didn't solve the problem. Any more ideas? Regards |
