8/18/2023 7:10 AM | |
Joined: 5/30/2022 Last visit: 9/28/2023 Posts: 387 Rating:
Hi TF_DongDong, Unified and Professional cannot be installed on the same PC due to incompatibility between databases, you can only have one, if you want to have both I recommend using a virtual machine, anyway, if you want to uninstall Professional correctly, review the following information: Installation error of WinCC Unified PC RT with WinCC Professional |
If this information really helps, you could use the Rate function. |
8/18/2023 8:49 AM | |
Joined: 5/21/2020 Last visit: 9/29/2023 Posts: 6 Rating:
Thank you for your answer. I have already tried the solution you suggested in "Installation error of WinCC Unified PC RT with WinCC Professional", "How do you uninstall a SIMATIC WinCC Professional or a SIMATIC WinCC Runtime Professional SQL Server Instance?", but I am getting the same error. |
8/18/2023 10:48 AM | |
Joined: 6/19/2017 Last visit: 9/29/2023 Posts: 7380 Rating:
Hello TF_DongDong, Please try to discuss your question in English language. This is an international community, and we try to focus on one language. Posting in English will help you to get more response to your question. This is the translation of your question:
Regards, |
