9/18/2009 9:18 AM | |
Joined: 10/7/2005 Last visit: 5/26/2023 Posts: 2965 Rating:
Hello Robert I certainly do NOT have an explanation and would be just as puzzled as you are by theobserved behaviour. Both logics should give you the same result/behaviour soI wonder if either your test conditions were differentand/or there is something else "strange" going on in your Block (are you jumping back somewhere ornot jumping were you think you should jump?). I suggest you post the whole Block/test project here for evaluation. |
Cheers |
