7/24/2008 4:56 PM | |
Joined: 5/24/2007 Last visit: 9/7/2023 Posts: 284 Rating:
Hi We have the same problem as published here:Process Object vs. Power Tags.
But we did not use any PCS7. We are working on normal WinCC with S7 and CFC. The system was working fine till a few days ago and suddenly now we get the licensing message and we found that the Tags were converted to Process Objects. Does anybody know why? Thanks in advance Krish |
Last edited by: CS Moderator at: 28.07.2008 15:15Last edited by: CS Moderator at: 28.07.2008 15:15new subject after splitting refered thread inserted |
7/24/2008 5:41 PM | |
Posts: 2661 Rating:
Hallo Krish, Did you install something recently and system thinks its TIA now? Can you check/post citamis.str and diagnose logs? Regards, Phantom |
7/25/2008 5:43 PM | |
Posts: 2661 Rating:
Thanks for the update Krish. This is good information! Regards |
