3/25/2010 6:19 AM | |
Posts: 9 Rating: (0) |
dear best engineer. I'm student at korean. My PLC 315-2DP Add to slave SEW MD60A Inverter. Inverter direct peer to peer conection RS-232 Configration. and 315-2DP via profibus to inverter configuration. Simatic configration set SEW inverter(GSD install complet) but SEW inverter run MOVITOOLS in Simatic. inverter no start-up how to move via 315-2DP??? Attachmentinclude.zip (233 Downloads) |
3/25/2010 6:57 AM | |
Posts: 691 Rating: (37) |
Have you set the Address of the Inverter 32 ( According to your HArdware Configuration) |
2/14/2019 11:42 PM | |
Joined: 9/27/2006 Last visit: 9/15/2024 Posts: 12282 Rating: (2683)
Hello Moong; Have you studied the DFP21 Profibus manual? That is where you will find all useful information to control your drive obver Profibus. Note that is seems you must define 3 words of data interchange, your screenshot shows only PD1 defined... https://download.sew-eurodrive.com/download/pdf/10516115.pdf Hope this helps, Daniel Chartier |
2/15/2019 5:11 AM |
Posts: 1283 Rating: (105) |
After Nine Long years, someone gets a response. Just a joke. |
