2/21/2017 2:46 PM | |
Joined: 5/22/2009 Last visit: 4/28/2022 Posts: 11 Rating:
Hello All, I have a Profibus cable with two connectors (6ES7972-0BA52-0XA0) from both sides. I tested the wiring connections using a cable tester and I found the following: Sheild -------- Sheild 1------------- 2------------- 3,5,6,8 ------------- 3,5,6,8 4------------ 5------------- 3,5,6,8 6------------- 3,5,6,8 7------------ 8,6,5,3 ------------ 8,6,5,3 9------------ Note: ON switch is activated in both connectors. Please check the attached photos. Is that connection correct? Best Regards, AttachmentProfi.zip (54 Downloads) |
