11/21/2017 7:50 PM | |
Joined: 9/27/2006 Last visit: 6/4/2023 Posts: 12033 Rating:
Hello Pelielo; I have no direct example of the S7-1500 connected to a Hilscher CIF-50-PB, so here are a few documents that should give you a head's up:
https://www.hilscher.com/fileadmin/cms_upload/en-US/Resources/pdf/PROFIBUS_Booklet.pdf https://www.hilscher.com/products/product-groups/pc-cards/pci/cif-50-pb/
Profibus Communication CPU 315F-2DP as a slave and Hilscher card
Communication with PC Profibus Card Other Than Siemens CP Card ..
]PROFIBUS with STEP 7 V13 - Siemens Support Note that the CIF-50-PB is a PC card, it has by itself no PLC capability; so the data areas that you will want to exchange with the S7-1500 will depend on the way you have configured either the Soft-PLC or OPC files provided with the CIF-50. Hope this helps, Daniel Chartier |
