8/20/2015 5:45 PM | |
Joined: 5/12/2006 Last visit: 3/27/2025 Posts: 22602 Rating:
Hello, if you CPU317T is allready configured as DP_Slave then you can import the GSD File for this PLC and configure it depends on the configuration in Step7. The GSD can downloaded here: To configure the PLC 1517 as DP-Slave you need a communication module CM1542 or CP1542. Regards Christoph |
8/20/2015 11:15 PM | |
Posts: 1 Rating:
That worked beautifully! Thanks so much for your help! |
2/17/2016 9:12 AM | |
Joined: 2/17/2016 Last visit: 6/25/2024 Posts: 4 Rating:
hi all, where I can find gsd file for cpu 317t-3pn/dp |
2/17/2016 9:53 AM | |
in the link i provided in the previous post from 8/20/2015 5:45 PM Better you read the post before you ask ! |
