2/11/2018 8:15 PM | |
Joined: 9/27/2006 Last visit: 3/19/2025 Posts: 12344 Rating:
Hello Deco; Please take a few minutes to read the following document, explaining the basic principles of configuring and using a DP/DP coupler: A DP/DP coupler is a special Profibus slave with 2 connected slave units; each side of the cpoupler is connected as a aslkave to a DP-master, and the data from one slave is transfered to the other, therfore permitting exchanges between the 2 DP masters as a gateway. See the attachment below. What are you planning to do with the COMMON PLC in your diagram? Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 2/11/2018 8:20:04 PMLast edited by: Jen_Moderator at: 2/12/2018 1:34:36 PMOptimized link. |
