10/25/2016 3:41 PM | |
Posts: 5 Rating:
10/25/2016 8:22 PM | |
Joined: 9/27/2006 Last visit: 3/22/2025 Posts: 12344 Rating:
Hello Mario; See if the information in this document can help you out: Which organization blocks can you use in STEP 7 (TIA Portal)? https://support.industry.siemens.com/cs/ww/en/view/40654862 This discussion will show you how to use the diagnostic buffer of the s7-1200 to see which diagnostic OB is requested to help you out: Online diagnostic? https://support.industry.siemens.com/tf/ww/en/posts/online-diagnostic/153643/?page=0&pageSize=10Hope this helps, Daniel Chartier |
10/26/2016 7:42 PM | |
Posts: 5 Rating:
I need an example, if you can have? I understand, but I can not do. Please |
10/26/2016 9:09 PM | |
Hello Mario; Have a look at this FAQ; the second method "Online diagnostics with Step 7 Basic" shows specifically the use of the diagnostic buffer: How can you manage block execution errors detected by the S7-1200 PLC? https://support.industry.siemens.com/cs/br/en/view/42908460 This video illustrates how to use the diagnostic buffer also: Hardware Diagnostics PLC Turtorials - YouTube Hope this helps, Daniel Chartier |
10/26/2016 9:59 PM | |
Posts: 5 Rating:
New print |
