6/20/2015 5:07 PM | |
Joined: 7/2/2013 Last visit: 2/21/2025 Posts: 7 Rating:
Dear sir, we have modified our profibus network with profibus active end terminator and tested with last node by removing from its device but still our plc(CPU416-2dp) is going to stop mode , what will be the solution for that, is there any problem if we are using in last node for IBA measuring system. Thanks and regards, Suresh S. Attachmenthardware configuration.docx (183 Downloads) |
6/22/2015 8:52 PM | |
thank you all for your suggestions, our iba measuring system is connected to DP master (1st port A2B2 Line). i have tested also again by removing network from our iba pc , the plc is going to stop mode due to priority class error OB85, as per our program we have called OB37 for IBA recording program i have attached in this post please refer and give me some ideas how resolve this problems. AttachmentIBA.docx (176 Downloads) |
