8/17/2019 12:18 PM | |
Joined: 9/27/2006 Last visit: 3/27/2025 Posts: 12344 Rating:
Hello Shubham; Hard to say where your problem resides with so little information. You are using 2 network transitions, the IE/PB link and the RCoax line. How is your network designed (a sketch would be very helpful). Do you have anything in your diagnostic buffer pointing a specific point where you lose connection? Do any of the equipment in your network show diagnostic LEDs when your problems appear? How is the RCoax line connected to the Ethernet side of the IE/PB link, what access points are used (are you using Scalance W 802, for example)? What distance is covered , what are the antenna gain and transmitter power in your system? Does your RCoax system follow the guidelines in this document: https://support.industry.siemens.com/cs/us/en/view/71814212 Are there other Profinet stations besides the ET 200S node you mention, along with the access points for the RCoax? Do any of them show problems with connection? Hope this helps, |
8/20/2019 8:16 PM | |
Posts: 7 Rating:
Thank you Daniel for your concern on my topic. we have resolved the communication break problem as per attached snap [snip] AttachmentPrrofinet NW setting.docx (55 Downloads) |
Last edited by: Shubham_panghate at: 08/20/2019 20:22:14Last edited by: Shubham_panghate at: 08/20/2019 20:25:41Last edited by: Jen_Moderator at: 08/21/2019 09:23:14Division of questions into seperate topics. |
8/21/2019 9:20 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by Shubham_panghate is split to a separate thread with the subject Setting of profinet to get PG/PC online with slave plc. Best regards |
