11/29/2013 1:45 PM | |
Joined: 10/1/2013 Last visit: 9/14/2023 Posts: 605 Rating:
Hi, you could use the "Open user communication" block "TCON" to set up a TCP connection to the G120Cs. As long as the connection is up the block sets a DONE but when the connection breaks there will be theERROR set to TRUE. In your S7 program you could monitor this ERROR bit. I hope this helps. /e: There is a application for PN diagnostics: http://support.automation.siemens.com/WW/view/en/24000238 |
11/29/2013 3:22 PM | |
Posts: 29 Rating:
Thanks a bunch ;) |
