9/28/2012 9:20 AM | |
Posts: 311 Rating:
Hello all, Is it possible to monitor the profinet communication between a PLC and some profinet I/O nodes ? Regards Per Olof |
9/28/2012 12:57 PM | |
Joined: 10/7/2005 Last visit: 3/17/2025 Posts: 3042 Rating:
Hello Per Olof yes it is possible to capture Profinet dataandeven good old Wireshark can generally be used for this (have a look to at the Ethernet capture setup FAQ's section). An arguably more sophisticated solution would be using PROCENTEC's Netilitiesin combination with ProfiTap. I hope this helps |
Cheers |
