1/8/2016 4:22 PM | |
Joined: 4/20/2007 Last visit: 3/4/2025 Posts: 728 Rating:
Thank you so much! One last question. I found some examples for using the drives in TIA. It seems they use a more generic GSD (XML) file for the drives, while I can also find the exact version. The firmware is also a different revision number. Should I be using the version from the example? I chose the latest possible firmware. The also look different in my HW. AttachmentDoc1.pdf (89 Downloads) |
1/10/2016 4:51 PM | |
Got ya, thank you very much! I appreciate the help! |
