3/29/2016 3:32 PM | |
Posts: 124 Rating:
first I recommend to you, don't remove memory card. then if i understood, another SD card does not work with siemens plcs except Siemens'Sd card! for data logging you can use automatically data logging from here, to save on your PC. |
3/29/2016 4:23 PM | |
Posts: 19 Rating:
first I recommend to you, don't remove memory card. then if i understood, another SD card does not work with siemens plcs except Siemens'Sd card! for data logging you can use automatically data logging from here, to save on your PC. Hello Saleh, Thanks for the suggestion. I actually meant Siemens SD card, as I know other cards dont work. If I understood it correctly, You are suggesting to use just one card as Program card which is also used for datalogging? Am I right? |
3/30/2016 10:41 AM | |
Posts: 19 Rating:
Hi Saleh, Thanks a lot for valuable suggestion. |
