10/5/2017 7:28 AM | |
Joined: 3/5/2014 Last visit: 6/23/2022 Posts: 5516 Rating:
hi Vannahsman, It depends on the instructions you are using. If you use instructions or versions of instructions that are only available to the newer Firmware, you need to change the program. have a look into the manual what changed. SIMATIC S7 S7-1200 Programmable controller regards, |
FCK WAR! |
