6/14/2011 12:00 PM | |
Joined: 12/5/2006 Last visit: 5/26/2023 Posts: 177 Rating: (2) |
Dear Experts Please find the complete Part Program . In the Manufacturing Cycles , I haded the following Line IDS=25 WHENEVER (($AA_IM[Z1]*10) <> $R32) DO $R32=($AA_IM[Z2]*10) $A_DBR_OUT[8]=$R32 After Entering the above line . he Following Alarm appears . 12550 Channel 1 Block name $A_DBR_OUT not Defined or option/function. Please Guide me , How to fix this Issue . Thanks in Advance AttachmentNCPLC_003.pdf (131 Downloads) |
6/14/2011 2:38 PM | |
Posts: 259 Rating: (5) |
Hi, Can you add NC backup. But not in pdf but in arc format. With regards, makaveli |
6/14/2011 3:10 PM | |
Dear makaveli Please find the attachment of NC Archieve AttachmentNCPLC_003.zip (121 Downloads) |
6/14/2011 8:27 PM | |
Hi, Ekalavya have right if machine work properly since new you need to check PLC fast inputs. If don't this is new machine or this program is new you should check what i say earlier and try $A_DBR[] for $A_DBR_OUT[]. In attachment you have few pages from documentation about communication between NC and PLCWith regards, makaveli AttachmentPLC Variable.pdf (118 Downloads) |
