4/26/2023 11:37 AM | |
Joined: 4/2/2019 Last visit: 6/6/2023 Posts: 12 Rating:
Hi, By any chance you have a sample program for unified comfort panel and S7-400H using ChangeConnection in JavaScript for redundancy? Thanks in advance, AJ ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/27/2023 07:06:07New subject after splitting |
4/27/2023 11:37 AM | |
Joined: 5/6/2022 Last visit: 9/25/2023 Posts: 290 Rating:
Hi afri.aj, He looking at the status of SIOS to see if he found any examples but he couldn't find any (and I don't know if there will be any) Alternatively, you could start with this example of a Comfort: “Connecting SIMATIC HMI panels with a SIMATIC S7-400H (WinCC V16 and STEP 7 V5.6)” and use the HMIRuntime.Connections.SysFct.ChangeConnection() function to change the connection between one CPU and another. It is what I can recommend, I hope it is useful. Best regards! |
