5/16/2015 4:53 PM | |
Joined: 10/21/2013 Last visit: 7/27/2023 Posts: 416 Rating: (28) |
Hi luis, pls take a look into this link the value from the rtd module are read as degree celsius with resoultion 10 so you need to convert the value from AIW To DI and DI to Real...divide the result by 10 to get the temperature value https://support.industry.siemens.com/cs/document/19598675?dti=0&lc=en-WW |
5/16/2015 7:09 PM | |
Posts: 13 Rating: (0) |
hi BALAKRISHNAN, thank you for your good solution. i willtry it and report the result warm regards |
5/16/2015 7:20 PM | |
Joined: 9/27/2006 Last visit: 4/25/2024 Posts: 12257 Rating: (2665) |
Hello Luis; Strange, the links works for me, I have opened the manual online once again. Now this manual has been aroud for quite a few years, so it is available from many sources on the web. Or try another link (that I tested) from another section of the Siemens Library. http://www.automation.siemens.com/doconweb/pdf/SINUMERIK_SINAMICS_04_2009_E/S7200SH.pdf?p=1 Hope tyhis helps, Daniel Chartier |
