7/22/2019 11:10 AM | |
Posts: 55 Rating:
Hi all, I am using 1211C cpu and I am trying to download programming script to get it working on the webserver. Before the script was a simple HTML file. I am trying to use js and CSS script as part of HTML5. However, the device is not able to accept it although the memory area is enough to load it. Which type of programming scripts are siemens able to host? I have attached the script folder. AttachmentUserPages.zip (23 Downloads) |
7/22/2019 11:53 AM | |
Joined: 7/9/2015 Last visit: 1/31/2023 Posts: 3277 Rating:
Hi, I did not check you file but - perhaps you get some help in this application example: Creating and using user-defined web pages on S7-1200 / S7-1500Regards, Towome
If my post was useful, please rate me - thank you! |
