2/11/2012 9:22 PM | |
Joined: 3/21/2006 Last visit: 3/2/2023 Posts: 10221 Rating:
Hello, What do you mean with 'THE SECREN IS NOT CLEAR' ? Basically the procedure is described in http://support.automation.siemens.com/WW/view/en/1142693 (Chapter 13). best regards, Hristo Mihalev |
2/13/2012 10:29 AM | |
Posts: 3037 Rating:
Hello, You can only make a backupwith the function, which describe the following manual in the chapter 13. Operator Panel OP25, OP35, OP45 Tweety |
2/21/2012 4:18 PM | |||||
Posts: 5 Rating:
Hi all, The link mentionned before seems to not work.This message appears:
Where could I get the procedure please? Thanks Ocap2 |
2/21/2012 6:12 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Found it in my archive Regards, Marcjan AttachmentOp25_e.pdf (141 Downloads) |
Problem solved? |
2/22/2012 8:49 AM | |
Posts: 5 Rating:
Hi, Get it now!!! Thank you very much for you quick help! Regards |
