11/4/2021 9:31 PM | |
Joined: 7/7/2010 Last visit: 4/25/2025 Posts: 15822 Rating:
You will need to install TIA Portal compatible WinCC Advanced above v11 and open the backup. It should allow the project to be upgraded. I do not know the upgrade path for WinCC Adv RT projects. Check the WinCC (TIA Portal) conference or FAQs about upgrade paths for WinCC. For regular portal projects, the upgrade path from v11 to v16 is:
It may be similar for WinCC Adv RT projects.
science guy |
