10/22/2024 11:23 AM | |
Joined: 1/21/2013 Last visit: 2/9/2025 Posts: 3524 Rating:
Hi,
Unfortunately I do not understand your current problems. I did some tests with WinCC Unified V19, Update 3 and a device version V19.0.0.2 and created a faceplate and a script module in my project library (booth for minimum device version V19.0.0.2). Inside the script module, Faceplate.FindItem() worked the same as inside the faceplate type.
What additional information do I need to know about using a script module inside a faceplate?
I am sure Siemens developers will make improvements in future versions of TIA Portal. However, if the developers do not know what needs to be improved, it may not be the problem you are experiencing that will be improved. So please report your problem to Siemens by creating a support request. Kind regards |
10/24/2024 5:55 AM | |
Joined: 8/6/2024 Last visit: 2/7/2025 Posts: 17 Rating:
thank you! I Will test again,my tia portal version is tia portal V19 Update2 |
