6/26/2007 9:54 AM | |
Posts: 14 Rating: (0) |
I hope this makes it clearer. Tag1-------> Tag2-------> Output Value = (either Tag1 or Tag2) dependant on event. Regards, |
6/26/2007 10:52 AM | |
Posts: 1084 Rating: (72)
You want the output to be the value of the tag that has changed last? |
6/26/2007 12:53 PM | |
Posts: 1776 Rating: (95)
Hi, as Ikkezelf mentioned above You can do this with a C action. Use both variables as trigger. |
6/26/2007 2:46 PM | |
Posts: 1275 Rating: (123)
Hi, As the guys said, you just gotta make the output value property dynamic, with a script which will set the tag to be displayed. |
