7/10/2016 9:33 AM | |
Joined: 7/3/2014 Last visit: 7/31/2023 Posts: 16 Rating:
Dear Dolpoong, Similarly you can search for your IO modules and from technical data tab you'll be able to get the current consumption, But it may be a little bit tricky for the IO modules as If you are supplying the signal from the same power supply you have to consider these signals in power consumption calculations. |
