2/15/2013 7:29 AM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
In Siemens PLC is possible to read out directly from PT100 (no 'convertor') or using a convertor which will convert mV from Pt100 to current or voltage signal good for Siemens PLC card. (Basically this output signals is 4-20mA). Like a converter -Weidmuller If you want to read out without converter (directly) it depends from type of Siemens PLC family. In case of S7-400 that card might be6ES7 431-7KF10-0AB0SIMATIC S7-400 S7-400 Automation System Module Data) for S7-300 -6ES7331-7KF02-0AB0 (more modulesSIMATIC S7-300 S7-300 Automation System Module Data) For s7-200 -EM231 RTD (S7-200 System Manual). Best regards, Hristo Mihalev |
3/18/2014 1:45 PM | |
Posts: 340 Rating: (6) |
new question is splittet to RTD PT100 Cl sensor for Compressor motor winding temp |
3/18/2014 4:50 PM | |
Posts: 2 Rating: (0) |
Sorry..Can U Explain me a bit..I will be very thankful Sir |
