5/2/2012 1:42 PM | |
Joined: 12/1/2009 Last visit: 5/2/2023 Posts: 669 Rating:
Dear m.shoaib khatana, please find attached the overview of available function modules for SIMATIC S7. In the list you find aFM354 for servo motors. https://www.automation.siemens.com/mcms/programmable-logic-controller/en/simatic-s7-controller/s7-300/function-modules/Pages/Default.aspx Here is the link to the FM354 direct. https://www.automation.siemens.com/mcms/programmable-logic-controller/en/simatic-s7-controller/s7-300/function-modules/FM354/Pages/Default.aspx Check if the FM354 is the right module to control your servo. Regards. |
Give us your feedback and show us your respect! |
5/5/2012 8:47 AM | |
Dear m.shoaib khatana , if it would be so easy special function modules(FM) would not exist. I am sure that there are vendors supplying servo controllers which you can simply connect to profibus/profinet. Just search on the internet forthem. I think that would be the best option for you, if you don't want to use an FM module. Regards. |
