6/19/2009 8:29 AM | |
Posts: 130 Rating:
Hi all, Can i get information on the "PULSE INPUT CARD" for PCS7 system? Can i get any documentation/ MLFB of the same? thanks & regards, |
6/19/2009 10:01 AM | |
Posts: 130 Rating:
Hi all, That was exactly what i was looking at. thank you very much. regards, |
6/19/2009 10:12 AM | |
Posts: 49 Rating:
6/22/2009 12:57 PM | |
Joined: 9/27/2006 Last visit: 5/30/2023 Posts: 12026 Rating:
Hello Pratap; "Isochrone" come from greek words and means "equal time". It is a synchrionisation concept between Profibus cycles and PLC cycles so that you can minimise the delays in I/O processing. Another use of the same concept, used in Profidrive applications, is called "Isochronous Real-time". You can read more on the principles involved here: http://support.automation.siemens.com/WW/view/en/15218045 Hope this helps, Daniel Chartier |
6/22/2009 1:22 PM | |
Joined: 5/28/2008 Last visit: 5/30/2023 Posts: 4446 Rating:
Here's attached the data sheet of the module 6ES7321-7BH01-0AB0. As mentioned in the data sheet it's isolated in group of 16. Regards, Attachment6ES7321-7BH01-0AB0.pdf (112 Downloads) |
Ayman Elotaify |
