8/1/2012 5:17 PM | |
Posts: 4 Rating:
Hi I have an error trying to make PWM work! Error number is 80D0... I made everything as is written here: https://www.automation.siemens.com/tf/WW/en/Posts/62908 . Unfortunatelly it doesn't want to work. I put some value to the QW1000, and configue everything in CPU properties. Please help, I cannot find this error on the google. |
9/12/2012 8:55 AM | |
Posts: 4 Rating:
Hi I am faceing the same problem, the status code is 80d0. no PWM output signal. any help. |
1/22/2013 12:24 AM | |
Posts: 15 Rating:
Same problem, no solution on all forum |
1/23/2013 12:08 AM | |
Posts: 15 Rating:
Are you sure? Look at attached picture, where is written, that RLY version has 2 pulse outputs...
1/25/2013 1:02 AM | |
Posts: 15 Rating:
Thank you Pegaia, it sounds logicly that relay outputs cannot output for example high frequencies in fact. I didnt realize that. You are true.
